Activity › Forums › VEGAS Pro › How to remove the noise from audio track?
  • How to remove the noise from audio track?
    Posted by M mokhriz A rahim on September 23, 2011 at 11:40 am
    Hi,my name Riz..
    Newbee in Sony Vegas video editing…
    Ok, I use my notebook to play a music then tranfer to my 7D using audio cable. Adjust the volume to minimal sound on my notebook.
    When I play the music using Sony Vegas, the noise really interrupt the music….
    My question is… any special tool from Sony Vegas to reduce or remove the noise… pls help me…..
    Thx
    Theo Van laar replied 15 years ago 3 Members · 4 Replies
  • Mike Kujbida
    September 23, 2011 at 1:34 pm
    Hi Riz.
    Do you mean that you used a program to create the music, then copied it to your 7D and then into Vegas?
    If that’s the way you did it, I have to ask why.
    It would be much easier and cleaner to save it as a WAV file and then import that directly into Vegas.
  • M mokhriz A rahim
    September 23, 2011 at 4:25 pm
    Hi, actually I used my player from notebook to play the music, then I play together while I press shoot video on my 7D.Means that, after done my recording, the video will play along with the music.
    …I will do some shooting aerobic show, my client need the song record while she do the aerobic move.
  • Mike Kujbida
    September 23, 2011 at 5:01 pm
    What’s the make and model of your camcorder?
    Does it have two independent audio channels?
    Can you record her mic to it’s own channel?
    She does have her own mic and not just your on-camera shotgun, correct?
    If you don’t need to hear her voice while she’s doing the exercise, just replace the audio track once when you’re in Vegas.
    If you do need to hear her, add the track in anyway, raise the volume of what you shot during her speaking parts and then lower it again when she’s done.
  • Theo Van laar
    September 24, 2011 at 11:43 am
    I use Izotope RX2 for that.
    https://www.izotope.com/products/audio/rx/
    Theo
