Activity › Forums › Adobe After Effects › How to remove specific things from an image ? example inside
  • Chris Buttacoli
    January 12, 2012 at 4:50 pm
    You may even do this in photoshop first before bringing it into AE.
  • Jm Chadillon
    January 12, 2012 at 8:16 pm
    if you want it to look good, photoshop it cut out the white in photoshop then export as PSD.
    OR if you are strapped for time
    in PS do a color selection on the yellow paper, adjust so you get your proper selection on the paper and make a new layer from selection, delete BG layer. export as psd and import into AE.
