Activity Forums Apple Final Cut Pro Legacy how to remove PsF interlace for web
  • how to remove PsF interlace for web
    Posted by D. Gregor hagey on March 31, 2009 at 5:24 pm
    I have a project that was shot 1080p 23.98, transferred to HDCAM 23PsF, cut on an AVID and then mastered to HDCAM at 29.97. I need to create a 23.98p QT for the web and I’m trying to figure out how to get rid of all the interlace artifacts. I’ve tried a few options with Cinema Tools and Compressor but none is giving a good result.
    Gregor
    D. Gregor hagey replied 17 years, 5 months ago 4 Members · 5 Replies
  • Chris Borjis
    March 31, 2009 at 5:35 pm
    in compressor the de-interlace set to combine or join the fields should do it.
  • Jeremy Garchow
    March 31, 2009 at 6:17 pm
    I’d set compressor to rev telecine.
    Jeremy
  • Chris Borjis
    March 31, 2009 at 6:36 pm
    D. let us know if both or only one of those suggestions worked.
  • Gary Adcock
    March 31, 2009 at 6:40 pm
    [D. Gregor Hagey] “I have a project that was shot 1080p 23.98…cut on an AVID and then mastered to HDCAM at 29.97. I need to create a 23.98p QT for the web and I’m trying to figure out how to get rid of all the interlace artifacts.”
    first things first.
    You do not have PsF files, that 29.97 file from the Avid is Interlaced.
    You can only remove the pulldown correctly (as jeremy suggested) if the project was mastered at 23.98 (sorry but doubtful) because the cadence can only be properly removed if it was added after the edit rather than on the master tape prior to the edit.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • D. Gregor hagey
    March 31, 2009 at 8:11 pm
    Thanks for all your suggestions. I finally got it to work with Cinema Tools by deselecting Standard Upper/Lower, which seems weird.
    Gregor
