Activity Forums Adobe Premiere Pro how to remove peak noise
  • how to remove peak noise
    Posted by Gabriel Scharis on May 4, 2012 at 9:44 am
    I’ve captures footage from a party where the sound was sooo loud that my camera captured the audio with a lot of cracks in it (don’t know the term for it really). Even when my camera’s audio level was set on the lowest Db possible.
    My question:
    Is there a way in adobe premiere 5.5 to lower these cracks? (don’t know the term/word for it)
    Thank you very much.
    Gabriel Scharis replied 14 years, 4 months ago 2 Members · 8 Replies
  • 8 Replies
  • Chris Tompkins
    May 4, 2012 at 1:18 pm
    if it’s distorted from being over modulated – not much you can do.
    Chris Tompkins
    Video Atlanta LLC
  • Gabriel Scharis
    May 4, 2012 at 3:32 pm
    Yeah, ah than there is nothing I can do..
    Is there a way to record footage without being overmodulated,
    when there is a very loud band playing etc?
    I already set the audio on the camera on the lowest so that is recording without peaks. but it is still overmodulated…
  • Chris Tompkins
    May 4, 2012 at 3:37 pm
    Of course. It’s done all the time.
    You’re best to set levels with the level coming in.
    You were using the on-cam mic were you?
    You’ll get better sound running a signal out of the sound board into your camera.
    It’s a learning experience for you.
    Chris Tompkins
    Video Atlanta LLC
  • Gabriel Scharis
    May 4, 2012 at 5:26 pm
    yes I was using the on-cam mic.
    What you are suggesting is using an external mic that I plug into the camera?
    I am using the sony PMW EX-1.
  • Chris Tompkins
    May 4, 2012 at 6:11 pm
    No. You bring cable and connectors and you take a line out of the mixing board. Feed it into your camera.
    Chris Tompkins
    Video Atlanta LLC
  • Gabriel Scharis
    May 4, 2012 at 9:50 pm
    yeah but than you lose all the background sounds. Like cheering people etc. There must be a way to record all the environment sound from a party without over modulating it. But how…
  • Chris Tompkins
    May 4, 2012 at 10:14 pm
    On cam mic – input 2
    Board feed – input 1
    Chris Tompkins
    Video Atlanta LLC
  • Gabriel Scharis
    May 6, 2012 at 1:12 pm
    oke, I will try that. I need to have some wireless xlr in and out sets.
    In adobe premiere both channels will be visible when I import the footage?
    By the way, thank you very much for your help.
