Activity Forums Compression Techniques How to remove negative timestamp from a media?
  • How to remove negative timestamp from a media?
    Posted by Madadi Smitha on April 9, 2014 at 11:47 am
    I have media for which the ffprobe -show_streams produces an output as below:(this is a media trimmed using an iPhone)
    [STREAM]
    index=0
    codec_name=aac
    codec_long_name=AAC (Advanced Audio Coding)
    profile=unknown
    codec_type=audio
    codec_time_base=1/8000
    codec_tag_string=mp4a
    codec_tag=0x6134706d
    sample_fmt=fltp
    sample_rate=8000
    channels=1
    bits_per_sample=0
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/8000
    start_pts=-80294
    start_time=-10.036750
    duration_ts=93213
    duration=11.651625
    bit_rate=48000
    nb_frames=95
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:default=0
    DISPOSITION:dub=0
    DISPOSITION:original=0
    DISPOSITION:comment=0
    DISPOSITION:lyrics=0
    DISPOSITION:karaoke=0
    DISPOSITION:forced=0
    DISPOSITION:hearing_impaired=0
    DISPOSITION:visual_impaired=0
    DISPOSITION:clean_effects=0
    DISPOSITION:attached_pic=0
    TAG:creation_time=2014-04-09 09:03:41
    TAG:language=und
    TAG:handler_name=Core Media Data Handler
    [/STREAM]
    [STREAM]
    index=1
    codec_name=h264
    codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
    profile=Constrained Baseline
    codec_type=video
    codec_time_base=1/48
    codec_tag_string=avc1
    codec_tag=0x31637661
    width=480
    height=360
    has_b_frames=0
    sample_aspect_ratio=0:1
    display_aspect_ratio=0:1
    pix_fmt=yuv420p
    level=21
    timecode=N/A
    id=N/A
    r_frame_rate=24/1
    avg_frame_rate=24/1
    time_base=1/12288
    start_pts=-123331
    start_time=-10.036702
    duration_ts=266752
    duration=21.708333
    bit_rate=471029
    nb_frames=521
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=und
    [/STREAM]
    I want to transcode it using ffmpeg and store it on cloud.Below is the command I use to do it:
    ffmpeg -i input.mp4 vcodec libx264 -pix_fmt yuv420p -vprofile baseline -preset veryfast -crf 20 -r 24 -s 480×360 -acodec libfdk_aac -ab 50000 -ar 44100 output.mp4
    [STREAM]
    index=0
    codec_name=h264
    codec_type=video
    width=480
    height=360
    has_b_frames=0
    pix_fmt=yuv420p
    level=21
    timecode=N/A
    id=N/A
    r_frame_rate=24/1
    avg_frame_rate=24/1
    time_base=1/12288
    start_pts=0
    start_time=0.000000
    duration_ts=266752
    duration=21.708333
    bit_rate=419200
    nb_frames=521
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=und
    TAG:handler_name=VideoHandler
    [/STREAM]
    [STREAM]
    index=1
    codec_name=aac
    profile=unknown
    codec_type=audio
    codec_time_base=1/44100
    sample_fmt=fltp
    sample_rate=44100
    channels=1
    bits_per_sample=0
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/44100
    start_pts=0
    start_time=0.000000
    duration_ts=957367
    duration=21.709002
    bit_rate=50108
    nb_frames=526
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=und
    TAG:handler_name=SoundHandler
    [/STREAM]
    The new media seems to show the trimmed off content too. ffplay seems to understand the transcoded media and play it fine. But other players like QuickTime or VLC play the trimmed content too. How do I transcode such that the trimmed part is removed in the transcoded video?
    Madadi Smitha replied 12 years, 4 months ago 2 Members · 2 Replies
  • Jim Sustacek
    April 10, 2014 at 12:29 pm
    The iPhone trimming may not actually be trimming the audio/video data, just marking trim points that FFMPEG may not understand.
    I would try re-doing the trimming with FFMPEG too. For example, in FFMPEG, “-ss 10” will start the new transcoded file after 10 seconds, and “-t 21” will trim it after 21 seconds. Adjust those values as needed (you may be able to find them in your FFPROBE output, otherwise you may have to view the file and/or experiment with different values).
  • Madadi Smitha
    April 10, 2014 at 12:54 pm
    Thanks Jim. I was able to fix this issue by using the trim filter.
