Activity Forums Adobe After Effects How to remove edge on a “Alpha Invert Matte” ?
  • How to remove edge on a “Alpha Invert Matte” ?
    Posted by Justin Mettam on October 11, 2013 at 4:35 am
    I am trying to key out the character so all that is left is his ground contact shadow. So I did a Alpha invert Matte on the beauty pass to cut out the character from the ambient Occlusion pass and then keyed it all onto a white solid. As you can see from my screen grab I am left with a fine hairline around the edge. What is the technique to remove this edge ?
    I am guessing I should crush the levels on the Alpha of the layer I am using as a matte ? Is there a better approach ?
    Eddie Potros replied 4 years, 9 months ago 4 Members · 4 Replies
  • Tudor “ted” jelescu
    October 11, 2013 at 7:32 am
    Use a Matte Choker
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Darby Edelen
    October 20, 2013 at 4:02 pm
    I would extend the alpha of the matte layer outward some using either matte>simple choker or channel>minimax set to maximum operating on the alpha channel.
    This may eat into the contact shadow some in which case you could roto a copy of the matted ambient occlusion pass to bring it back.
    Darby Edelen
  • Justin Mettam
    October 20, 2013 at 9:23 pm
    Thanks for responding. I ended up using this light wrap tutorial that someone posted.
    https://maltaannon.com/articles/after-effects/ce-lightwrap/
    Justin Mettam
    PreViz & 3D-Generalist
    mettam@hotmail.com
    415 261-7633
    https://mettam.wix.com/3dartist
  • Eddie Potros
    November 16, 2021 at 8:09 pm
    Years later and this helped me. Thanks. I used minmax with operation set to minimum and radius of 25 (depends on footage) and channel set to minimum
