Activity › Forums › Adobe After Effects › How to remove color banding on circle gradient?
Posted by Ivan Kychygin on June 20, 2019 at 6:08 pmHi guys!
Here is screenshot for part of my composition
Does anyone know how to remove color banding on circle gradient?Thanks!
Richard Garabedain replied 7 years, 3 months ago 4 Members · 4 Replies -
Doyle Lewis
June 20, 2019 at 7:01 pmDid you set your project to 32 BPC (Bits Per Channel) will increase the number of bits used to create your colors allowing you more steps between your bands. you can change your bpc on the bottom of your project tab.
Doyle Lewis,
Assistant Location Manager
Warner Brother Pictures -
Ivan Kychygin
June 20, 2019 at 7:48 pmThanks for answer!
Yes, I set 32 bpc and it helps a bit.
Also I’ve added 1% of grain with adjustments layer and gradient become much smoother.
I wonder is there any other techniques instead adding grains to gradient? -
Michael Szalapski
June 20, 2019 at 8:14 pmAdding noise or grain is the most common technique. Now, there are many ways to add that variation/dithering that you’re looking for. I, personally, like to use either Fractal Noise (with some tweaking on the look) or a stock grunge map (like old paper) very lightly overlaid.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Richard Garabedain
June 25, 2019 at 3:36 pmwell just because his project is at 32 bits doesnt mean his render will be perfect. or does it…i remember having trouble with it
