Activity › Forums › Adobe After Effects › How to remove black bars from After Effects Template…
  • How to remove black bars from After Effects Template…
    Posted by Ivan Jaquez on August 27, 2020 at 7:11 pm
    Hello guys! I’m new to AE. I just got a free template for a slideshow to make things a lot easier. I’m using AE 2018. When rendering/exporting, the video has black bars(top and bottom). In addition, the video clips I’ve imported into the clip are cut off due to the black bars. I would like to export the After Effects clip without the black bars. Any help with this? I’ll share the template in case you would like to take a look at it. I have full rights in doing so. Thanks in advance.
    https://www.dropbox.com/s/osf2zjcvtnxzyy7/fast-creative-slideshow.zip?dl=0
    Ivan Jaquez replied 6 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    August 27, 2020 at 8:06 pm
    In the folder ‘Assets’ open up the composition, “All”. In that comp, Press the ‘Shy’ layers button(looks like a guy peeking over a fence). That will show the hidden layers, just delete or turn off the layer “Letterbox”
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ivan Jaquez
    August 27, 2020 at 9:29 pm
    Thanks a lot, Johnny! It worked. You’re a life saver. Take care.
