Activity › Forums › Adobe Premiere Pro › How to Remove a Nail on the Wall Behind the Talking Head?
Posted by Alan Knight on July 26, 2014 at 4:29 amHi, I have footage of a talking head in front of a white wall but there’s a big nail or screw in the wall next to the guy which I find very distracting. I’m guessing there must be a way to remove it easily in Premiere since it does not need to be motion tracked. Can someone assist me on how to achieve this please? I’m assuming it must involve creating a static mask?
Alan Knight replied 12 years, 2 months ago 7 Members · 9 Replies -
Declan Smith
July 26, 2014 at 1:24 pmHi,
If there is no tracking and nothing obscuring the nail (ie it’s always in view) then you could duplicate the footage onto another layer, add a 4 or 8 point garbage matte around the nail, then move the footage a few pixels left or right or up or down until you get a clean part if the wall to take its place. You will also need to feather the mask to make it blend well. Not sure whether you need to move the footage then mask or mask then move as I am not in front of a computer right now.Declan Smith
https://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase“it’s either binary or it’s not”
Michael Yu
July 26, 2014 at 9:59 pmWell you can remove it but you will also need to replace and cover up the area, which is in effect removing it.
If you have just premiere, duplicate the clip so the new one is on top. Use a garbage matte (four or eight depending on what works best) and crop around another part of the white wall that matches the look of what the wall would be theoretically if there was no nail there. Then select and move the wall clip and place it over the nail.
If the wall looks the same throughout it should work okay, but it’d be easier and give better results if you used like After Effects or Photoshop to better blend the image on top.
Richard Angle
July 26, 2014 at 10:25 pmDeclan’s advice would be perfect if only Premiere Pro included feathered edges with their garbage mattes. Not sure why they left it out as it usually makes the supplied garbage mattes almost useless. If you happen to be on Premiere Pro CC, try the oval tracking mask under the opacity settings in the effects control panel instead. This new feature allows you to feather the edges. Do as Declan advises in terms of duplicating the clip and shifting the bottom layer. But apply the tracking mask instead.
If you dont have CC, try the crop effect instead with feathered edges and the instructions above.
Richard Angle
Ann Bens
July 27, 2014 at 12:32 amIf you have CC14 follow instructions as per Michael Yu but instead of using a Garbage Matte use the Opacity Mask option. This you can feather. Garbage Matte you cannot. Well you can but with a workaround.
Adobe Certified Expert Premiere Pro CC
Adobe Community Professional -
Paul Neumann
July 27, 2014 at 5:47 pmYep and you have full Blend capacities under the Opacity section of your Effects Panel.
Alan Knight
July 28, 2014 at 3:07 amThanks everyone – Im on CC2014 – I’ll follow the tips here and give it a shot!
Alan Knight
July 28, 2014 at 3:08 pmOK Im trying to follow Michael Yu’s method.. ive got a clean elliptical selection drawn over a clean part of the wall… how do I copy and move that over the nail? I tried a bunch of modifier keys while dragging.. (im on Windows)…
Bala Chandran
July 29, 2014 at 2:40 pmIn CS6 you move the layer under Effect Control> Position. I guess it would be similar in CC.
Alan Knight
July 30, 2014 at 2:13 pmOK so for 2 of the 3 clips I was able to simply create a duplicate of the video layer which I put on the layer above the original. I then created on that new layer a small ellipse around a clean part of the wall just above the nail, then repositioned that elliptical mask OVER the nail to hide it.
Unfortunately, in the 3rd clip, the suject’s hand passes over the nail at one point. Whats the solution at this point? A lengthy one I can think of is to add a keyframe for the opacity of the mask at the exact time the hand comes over, so that the mask has 0% opacity at that time, thereby allowing the entire hand to show.
Is this the suggested (or only) way for Premiere Pro CC 2014?
