Activity Forums Adobe After Effects How to refer to the comp element is nested in
  • How to refer to the comp element is nested in
    Posted by Andreas Woelfl on September 29, 2016 at 9:49 am
    Hello everybody,
    I would like to write an expression for the stroke thinkness of a ShapeLayer.
    The thickness should be given by a slider of an AdjustmentLayer in the MainComp.
    I cannot use the expression comp(“MainComp”), because there will be different copies of the MainComp and each one will have a different name. Each copy will have a different stroke thickness.
    Here the scenario:
    MainComp
    – AdjustmentLayer
    – PreComp
    — ShapeLayer
    So the ShapeLayer is inside of a PreComp. The adjustment layer is inside the MainComp, together with the PreComp.
    Is the some kind of expression that I can use. Instead of “thisComp” somthing like “jumpOutsideThisComp” 🙂
    Thanks a lot for the help.
    Cassius Marques replied 9 years, 11 months ago 2 Members · 1 Reply
  • Cassius Marques
    September 29, 2016 at 5:22 pm
    The “comp” object has no method that returns where the composition is placed at. Since it can be inside more than one other composition.
    But anyway if
    [Andreas Woelfl] “there will be different copies of the MainComp and each one will have a different name.”
    why don’t you reference them by name?
    I really don’t get it.
    Cassius Marques
    http://www.zapfilmes.com
