Activity › Forums › DSLR Video › How to reduce gradient jumps
Posted by Mark Gin on July 25, 2011 at 8:56 amHi,
Got this problem with my t2i (after some post enhancement):
https://img694.imageshack.us/img694/7317/mvi0911dnxhd0001116.jpgHow can I at least reduce these transition jumps (in post – AE) so they won’t be so noticed?
Mark.Pete Burger replied 15 years, 1 month ago 6 Members · 15 Replies -
Mark Gin
July 25, 2011 at 4:47 pmWhy should random noise help in this case?
I don’t have AE on this station but I have used Gimp’s “HSV nosie” on the frame I sent here.
The result is a little grainy image (that would also create a harder job for the encoder) – the imaged is still posterized well:
https://img843.imageshack.us/img843/1353/mvi0911dnxhd00011162.jpg -
John Kaley
July 25, 2011 at 5:14 pmNoise will help blend the gradients together, but it require too much “noise”. You also may want to have a look at “Magic Bullet DeNoiser”.
Tom Nelson
July 25, 2011 at 6:49 pmI would consider this to be more of a banding issue. GenArts’ Sapphire effects has a DeBanding plugin that could take care of them – you can download it for free for three weeks before you have to pay the $2800 to keep it.
Tom Nelson
Videographer/Editor
Essex Television Group -
Joseph W. bourke
July 28, 2011 at 5:47 pmHi Mark –
You don’t say in your post whether the banding is in your original T2i footage, or whether it’s being introduced in post (which I assume it is). If it’s not in the original image, you may want to change the color bit-depth settings in your AE project, if that’s what you’re using. You have the option of using 8, 16, or 32bpc (bits per channel), and this can have a great effect in reducing gradient banding. Check out this info from Adobe:
https://help.adobe.com/en_US/AfterEffects/9.0/WS81984DEB-D195-4822-9A06-EA0D00A0ECC7.html
If you look at Todd Kopriva’s info at the bottom (and you’re using CS5), there’s specific info on reducing gradient banding in his link.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
David Johnson
July 28, 2011 at 5:53 pmYou might also search the COW for many detailed tips on reducing banding such as grain and adjusting individual color channels … has come up very often over the years in the After Effects forum.
Mark Gin
August 1, 2011 at 2:49 pmGreat plug-in! Seems to be not too filtered and has good edge preserving (at the right settings of course).
Thanks! -
Mark Gin
August 1, 2011 at 3:03 pmHi Joe,
My footage comes from the t2i with Technicolor CineStyle picture style.
https://www.technicolor.com/en/hi/cinema/filmmaking/digital-printer-lights/cinestyle
It passes Technicolor’s LUT in AE and then I add edge enhancement.I changed it to 16bpc and the result is great! Unfortunately, final encoding will pass through 8bpc.
Mark Gin
August 1, 2011 at 3:07 pmHmm, good idea.
I haven’t done this before because I didn’t know the anomaly’s name. 🙂
Great stuff can be found here -
Joseph W. bourke
August 1, 2011 at 4:07 pmHi Mark –
You may want to think about changing your workflow a bit and shooting your T2i footage Neutral, then doing the FX pass in 16 bit in After Effects. I think you can pretty well approximate the in-camera presets in AE, and get them looking squeeky clean, then output to 8bit if you have to. I’m hoping someone will weigh in here who knows a bit more about the DSLR workflow. I have a T2i, and always shoot in Neutral, then so any FX work in post with AE.
Joe Bourke
Bourke Media
