Activity Forums Adobe Illustrator How to recreate exactly this shape?
  • How to recreate exactly this shape?
    Posted by Massimiliano Cestari on June 6, 2019 at 6:39 pm
    I need to recreate the object in the picture with illustrator.
    …and I should mention I’m a beginner, of course ☺
    I can’t get it accurate by scanning or tracing a picture because it’s not flat. I’d like to have it precise by re-drawing it. What would be the best way to translate it in vectors?
    Max
    Massimiliano Cestari replied 7 years, 3 months ago 2 Members · 6 Replies
  • Kalleheikki Kannisto
    June 7, 2019 at 4:55 am
    A failry easy method would be to make one circle the edge of which matches the shape of one of the protrusions, filling a piece of the inside, then copy it around the shape edge, finally combine the circles into one shape with pathfinder and deleted the remaining inner shape.
    Senior Graphic Designer
  • Massimiliano Cestari
    June 7, 2019 at 11:00 am
    Thanks Kalleheikki Kannisto!
    That’s pretty much what I did.
    I managed to get most of it but the outline is still quite off…
    June 8, 2019 at 8:42 am
    You can place the original photo into the illustrator file on a layer below the illustration and set the “fade placed images to 50%” checkbox on. Then you can use that as a reference to match the placement exactly. There are some clear differences here. For example you have 34 “bumps” on the edge while the original has 28 of them.
    June 18, 2019 at 5:09 pm
    Thx and sorry for the late reply ☺
    In the end I made a fusion from the top circle to the bottom circle and put it on the edge, adjusting the single circles to make them fit the original shape on the layer below.
    I think It’ll be ok.
    Max
    June 19, 2019 at 12:36 pm
    Looks like you’ve got it.
    June 19, 2019 at 1:16 pm
