Activity Forums Adobe Premiere Pro How to record voice over in mono?
  • How to record voice over in mono?
    Posted by Joel Arvidsson on February 21, 2017 at 8:19 pm
    I want to record voice over in premiere in mono. Im recording with a mono mic but Its gets recorded as a stereo track with only voice in one channel? Where do you change this? Seams like even if i set a mono track, the voice over will record in stereo plus one empty channel. Where should i do the changes? Is it in premieres channelmixer or perhaps i have looked in the wrong end.
    //Joel
    Jon Doughtie replied 9 years, 6 months ago 3 Members · 2 Replies
  • Jo Liesendahl
    February 21, 2017 at 8:25 pm
    Hi Joel,
    make a new audio track in your timeline, set it to mono.
    Add the record-symbol to your audiotrack-icons, activate record on that mono track.
    Best,
    Jo
  • Jon Doughtie
    February 21, 2017 at 8:26 pm
    Unless you go back and reset your timeline to have mono tracks, it might be simpler to simply make the mono track play as stereo.
    In the Project/Bin panel, select your mono clip. Choose Clip > Modify > Audio Channels. In the Modify Clip dialog box, select Mono As Stereo, and then click OK. Note: You can apply the Modify Clip command to a mono clip only in the Project panel, before the clip appears in a Timeline panel. If you have already placed it in the timeline, you’ll need to place it again.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
