Activity Forums Compression Techniques How to Record mjpeg video in a file with synchronized time Information
  • How to Record mjpeg video in a file with synchronized time Information
    Posted by Adeel Zahid on September 13, 2012 at 11:24 am
    I am new to ffmpeg and I was trying to record the MJPEG video from an IP camera and store it in a file. Recording worked ok and file was created on the disk. When I played the video It played only for 2 minutes but it was recorded in around 10 minutes. Are there any flags in ffmpeg that I can use to save the timing information along with video data?
    Regards
    Adeel
    Reuben Martin replied 13 years, 11 months ago 2 Members · 2 Replies
  • Adeel Zahid
    September 14, 2012 at 7:46 am
    Hi again,
    I have used following commands to record the video in order
    ffmpeg -f mjpeg -r 8 -i https://c-cam.uchicago.edu/mjpg/video.mjpg -vcodec mpeg4 -b 1000000 -r 8 video_file.avi
    Then I omitted the most of the flags and tried like this
    ffmpeg -f mjpeg -i https://c-cam.uchicago.edu/mjpg/video.mjpg video_file.avi
    But the problem is that the duration of recorded file is 9 seconds where as the actual recording time is around 2 minutes. I finally tried setpts filter that is supposed to insert the timestamps. The command is as follows
    ffmpeg -f mjpeg -i https://c-cam.uchicago.edu/mjpg/video.mjpg -vf "setpts=1*PTS" video_file.avi
    But result was still the same. Recording time was way more than video duration.
  • Reuben Martin
    September 16, 2012 at 1:10 am
    It’s an IP cam. It lies about it’s frame rate. (It says it’s frame rate is 25fps but that’s crap)
    When it can’t send the frame in time it just drops it. Playback at a fixed framerate will no ever be quite right, although using the framerate of 8 should be somewhat in the ballpark.
    ffmpeg -re -r 8 -i https://c-cam.uchicago.edu/mjpg/video.mjpg -r 8 -vcodec libx264 -preset slower -vprofile high -trellis 2 -crf 22 -pix_fmt yuv420p -an -f mp4 IpCamCapture.mp4
