Activity › Forums › Sony Cameras › How to record, download then delete files on SxS in a Mac
  • Jay Levi
    April 28, 2012 at 7:15 pm
    Can so
    Eone explain how to format the sxs or erase all files on the cards on location with the camera, i only have my ipad with me so I can’t use the software to fiddle with the files, the menu seems to oly allow you. To erase one cl ip at a time
    Ex1
    Been a while since this thread was posted so hope its ok to ask since i cant find the simple answer and i am in the uk and have not used this cam for a while
  • Bob Cole
    April 28, 2012 at 7:59 pm
    Turn the camera on (either Camera or Media).
    Go to the menu, navigate along the left side to the very bottom option: “Other”
    Click to the right, navigate down to where it says “Format Media”
    Click and go to the card you want to reformat, click on it, confirm a couple times and the card should be reformatted. You will lose all material on the card.
    Good luck.
    Bob C
  • Jay Levi
    April 28, 2012 at 8:10 pm
    so your saying its in the camera menu instead of the playback
    ill try this tomorrow, the guys took it back to their place
    THANKS
  • Bob Cole
    April 28, 2012 at 9:04 pm
    [Jay Levi] “so your saying its in the camera menu instead of the playback”
    No. Either menu. But I’m using an EX1R so it may be slightly different.
  • John Corbett
    May 9, 2012 at 4:44 am
    This is fantastic workflow advice. If someone has ClipBrowser installed and is pulling clips from an external SxS reader, is the SxS driver also required? Or is that only needed if you’re pulling the clips directly off the camera? Thanks in advance for any advice!
  • Don Greening
    May 9, 2012 at 5:03 am
    The workflow is slightly different depending on what platform you’re using, which you didn’t mention.
    Since I only know the Mac workflow:
    You don’t need any driver if you’re pulling clips directly from the camera via the USB port. Your camera’s card icons will show up on the desktop like any other attached device or volume. The SxS driver exists so that the naked SxS card is recognized as an attached device. For example, a Macbook Pro with a built in Express 34 slot needs the SxS driver to “see” the card. I’m not sure about an external SxS card reader attached via USB. If you’re in doubt just try it without the driver. If the reader doesn’t show up on the desktop then install the free SxS driver from Sony.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
Page 4 of 4
