Activity Forums Adobe Illustrator How to recolour existing layers?
  • How to recolour existing layers?
    Posted by Matthew Polack on February 3, 2010 at 10:52 pm
    I’m an experienced Corel Draw user but a novice with Illustrator.
    I am working with a multi layered Illustrator document and am trying to simply recolour a layer.
    In Corel Draw this is a simple process:
    1.) Click on layer (object) in side panel
    2.) Press Colour Swatch…done.
    In Illustrator I have tried the same intuitive process…
    1.) Click on layer in side panel.
    2.) Change colour stroke.
    Unfortunately nothing happens.
    Could someone explain to me how one changes the colour in Illustrator when it is selected in the side panel.
    Thanks.
    Matthew Polack replied 16 years, 4 months ago 1 Member · 1 Reply
  • Matthew Polack
    February 3, 2010 at 10:55 pm
    Ok..have just solved this…apologies…
    In Illustrator one needs to double click on the side circle to properly select the layer.
