Activity › Forums › Apple Motion › How to re-create this text effect in Motion
Posted by Dan Brearley on August 15, 2013 at 3:55 pmHi everyone,
Couldn’t find any previous posts relevant to my query. And it’s quite a specific one too.
I’m looking to create something similar to the text effect in this video. I am fairly new to Motion and thought someone out there might be able to help me.
https://www.youtube.com/watch?feature=player_embedded&v=E6w6WGokjTU#at=45
Many thanks in advance.
Dan
Simon Ubsdell replied 13 years, 1 month ago 3 Members · 7 Replies -
Sandeep Sajeev
August 15, 2013 at 5:41 pmHi,
There seem to be a quite a few different Text effects employed through out the video. All of them are very simple to create in Motion. So if you could indicate which one(s) exactly you’re referring to, we can chip in with specific information.
Sandeep.
Dan Brearley
August 15, 2013 at 5:46 pmHi Sandeep,
Thanks for your response. Sorry, you’re right there are a couple of different efect, I guess I thought they were kind of similar.
In the first few seconds after the main title, the effects on the sequence of words “mistakes”, “accident”, “loose” and “free” is what I’m looking to imitate.
I’m wondering if there is a filter / template I could use or if it is keyframing job.
Cheers,
dan
Sandeep Sajeev
August 15, 2013 at 5:55 pmMistakes: Just Keyframe Opacity.
Accidents: Ditto.
Loose: Keyframe Opacity and Position to animate off screen or use a Throw Behaviour.
Free: Same as Loose.Why not look at the inbuilt Text Behaviours inside Motion? There are a LOT of options. Click on the Behaviours icon (the cog) on the right side of the UI and explore the various Text Animation/Simulation options.
You could make something far more interesting with almost no effort at all. Bear in mind that you can combine multiple Text Behaviours to create very unique animations.
Sandeep.
Dan Brearley
August 15, 2013 at 5:58 pmThanks Sandeep, I did have a look at the Text behaviours, but didn’t find anything close enough really.
Thanks for your thoughts!
Simon Ubsdell
August 15, 2013 at 6:40 pmA lot quicker than keyframing, why not simply add a Wriggle or Randomize to the layer opacity?
Simon Ubsdell
http://www.tokyo-uk.com -
Simon Ubsdell
August 15, 2013 at 8:18 pmSorry, I should have said that you should try an Oscillate Behavior on the opacity to more closely mimic the effect in the example. Shorten the Oscillate Behavior to wherever you want the flashing to stop. Set the Wave Shape to Square to get clean On/Off behavior.
Randomize and Wriggle are fun but more funky than what we’re seeing there.
Simon Ubsdell
