Activity › Forums › Adobe After Effects Expressions › How to randomly change color of characters
  • Christian Hopkins
    September 23, 2013 at 12:47 pm
    Just came across this thread – I realise it’s old, might be useful to others.
    I used Dan’s code, which works perfectly, but you need to use RGB percentages (0-100), rather than the standard RGB values (0-255), there’s a great convertor I found here: https://andylangton.co.uk/tools/colour-converter.
    Hope this helps.
  • Daniel Blokland
    October 2, 2015 at 2:14 pm
    Hi Dan,
    I’m trying to do the same sort of thing but have specific colours for each letter (image basically a rainbow, each letter one colour), don’t suppose you know how?
    I tried altering you code but couldn’t get the desired effect.
    I was trying to combine it with “selectorValue * textIndex/textTotal” but couldn’t get it to work.
    I guess its the “idx = Math.floor(random(palette.length));” that needs changing but I haven’t a clue to what.
    seedOffset = effect("Slider Control")("Slider");
    seedRandom (seedOffset+textIndex, true);
    //seedRandom(index*textIndex, timeless=true); //works but not desired effect
    palette = [[86,0,0],[100,38,18],[100,96,0],[0,73,0],[0,80,100],[39,40,99]];
    //idx = textIndex/textTotal;
    palette[idx]
  • Dan Ebberts
    October 2, 2015 at 4:10 pm
    In what way is it not working?
    Dan
  • Daniel Blokland
    October 2, 2015 at 4:30 pm
    At the moment each letter picks a random colour – that works.
    But what I want is for each letter to pick the next colour in the array and then possibly loop around again?
    The reason I’m trying to get this too work is that I kept getting instances where two or more letters next to each other had the same colour.
    So I thought what might be useful is to have greater control – have each letter match the next colour in the aray.
    Sure, there less dynamic ways of doing this but I have some scripts that allow me to replace text in AE so that I can easily localise/translate the text (something I have to do in my job a lot).
    (A lot like variables in photoshop if you are familiar with those).
    At the moment I’m having to translate a line of text that basically has rainbow colours – each letter follows on to the next colour in the rainbow and then loops, and doing it by hand is going to take a long time in all the languages 🙁
    This script makes me feel so close yet so far 🙁
    Anyway if you’ve got any ideas I’d really appreciate it!!
  • Dan Ebberts
    October 2, 2015 at 4:44 pm
    Like this maybe (with black text and white fill color animator):
    idx = (textIndex-1)%palette.length;
    palette[idx]
    Dan
  • Daniel Blokland
    October 5, 2015 at 2:09 pm
    Thank you very much! Works perfectly for the rainbow.
    I’m having a play around to see if I can get some other uses out of the code for future projects.
    I was thinking of setting up a slider to highlight a single word in a paragraph – if I get it working I’ll post it.
    Anyway thanks again!!
    D.
  • Nikki Van onna
    March 25, 2016 at 12:28 pm
    Hello Dan and Daniel,
    I’m trying to get this working too, only I think I’m missing something, cause it’s not really working.
    So far I set everything up the way it’s described earlier in this post:
    dur = 1; // length of time to hold each color
    seedRandom(textIndex,true);
    seg = Math.floor((time+random(999))/dur);
    seedRandom(seg,true);
    palette = [[0,33,65],[93,11,14],[100,83,0]];
    palette[idx]
    Now I also want to have a version where you never have the same color in a character next to each other.
    When I change the palette like Dan suggested:
    palette = [[0,33,65],[93,11,14],[100,83,0],[0,33,65],[93,11,14],[100,83,0]];
    palette[idx]
    It’s not animating anymore, not jumping to other colors over time.
    Do you maybe know a solution? That would be great.
    In short:
    I want letters to jump from one color to another, in a range of 3 colors over time.
    But I never want the same color in characters that are next to each other.
    Would be great if you could help me out.
    Thanks in advance!
    Nikki
  • Fernando Huezo
    May 20, 2016 at 11:55 pm
    Sorry for my question and my english.
    Where I have to write the expression, in what parameter?
    which animator he its using in te text?.
  • David Cabestany
    June 21, 2016 at 4:02 pm
    Thank you, thank you thank you.
  • Marissa Joyner
    March 30, 2018 at 7:23 pm
    Hi Dan,
    What if I wanted to define the colors in the palette arrays with a few color pickers instead of numerical values? I tried this:
    x=effect("Color Control")("Color");
    x2=rgbToHsl(x);
    y=effect("Color Control 2")("Color");
    y2=rgbToHsl(y);
    palette = [x2[0], x2[1], x2[2], x2[3]],[y2[0], y2[1], y2[2], y2[3]];
    palette[idx]
    I don’t get an error but the color reverts to the original text color (black), I know I’m missing a piece here…
    Marissa
    x2=rgbToHsl(x);
    y2=rgbToHsl(y);
    palette[idx]
    After Effects template maniac
    https://www.fluxvfx.com/
Page 3 of 5
