Activity › Forums › Adobe After Effects Expressions › How to randomly change color of characters
  • How to randomly change color of characters
    Posted by Sabri Liefert on March 16, 2013 at 12:40 am
    Hello,
    i want randomly animate the colors of individual characters in a word
    and after a few seconds the colors should transform to white.
    I tried the text animator “hue” with randomize order and seed.
    But that has the drawback that i have to use a fill color before. If i use white text the hue setting doesnt apply.
    The hue setting is also very limited. If applied it doesnt change all letters. Aprox. 20% keep the fill color.
    I think i have to apply an expression selector to the fill color. But i dont know how to define?
    It would be ideal if i could define a color palette for the random colors.
    Thank you very much!
    Dan Ebberts
    replied 6 years, 2 months ago
    14 Members · 42 Replies
  • 42 Replies
  • Dan Ebberts
    March 16, 2013 at 12:50 am
    What do you mean by “randomly animate”?
    Dan
  • Sabri Liefert
    March 16, 2013 at 1:01 am
    Hello Dan,
    the individual characters should change colors randomly over time.
  • Sabri Liefert
    March 16, 2013 at 1:11 am
    This is a screen shot of my amateurish attempt to write the expression.
    The code was only copied from an other project.
    But miraculously worked half way.
    I really dont understand the syntax for expression selectors.
  • Dan Ebberts
    March 16, 2013 at 2:30 am
    Try this:
    text color = white;
    Fill animator color = black;
    Expression Selector Amount = 50%,50%,50%;
    Expression Selector Amount expression:
    seedRandom(textIndex,true);
    w = wiggle(1,50);
    linear(time,0,5,w,[0,0,0])
    Dan
  • Sabri Liefert
    March 16, 2013 at 3:31 am
    That works!
    Is it also possible to take colors from a palette for the random colors.
    Like i have 5 defined colors which rotates randomly at each character?
  • Dan Ebberts
    March 16, 2013 at 4:09 am
    If you change the text color to black and the fill color to white, this will give you random colors for each character from a palette:
    palette = [[100,0,0],[0,100,0],[0,0,100],[0,100,100],[100,0,100],[100,100,0],[100,50,0]];
    // [red,blue,green,cyan,magenta,yellow,orange]
    idx = Math.floor(random(palette.length));
    palette[idx]
    Dan
  • Sabri Liefert
    March 16, 2013 at 1:10 pm
    Thank you very much. That gives me a lot more control for the colors.
    How can i rotate/random change the colors for the letters? The color palette should stay the same.
  • Dan Ebberts
    March 16, 2013 at 3:05 pm
    dur = .25; // length of time to hold each color
    seg = Math.floor((time+random(999))/dur);
    seedRandom(seg,true);
    palette[idx]
    Dan
  • Sabri Liefert
    March 16, 2013 at 3:44 pm
    Thank you! Exactly what i wanted.
    [But i can produce only the basic 6 colors. Doesnt matter which rgb values i enter in the brackets?]`
    edit: I can produce rgb colors. It hasn´t worked because i had another effect on the layer. sorry for that!
  • Gary Txeusd
    March 26, 2013 at 4:05 am
    Hi Dan,
    Does this effect applies to CS6 ? I can’t seem get it work ?
Page 1 of 5
