Activity Forums Adobe After Effects How to raise your game with transition effects
  • How to raise your game with transition effects
    Posted by David Honan on October 14, 2014 at 2:00 pm
    Hi from still wet cold & windy York UK,
    I want to raise my game in terms of transition effects and came across a cluster of transition effects in this clip:
    https://www.youtube.com/watch?v=XQRPfxweflQ
    Now if i want to graduate beyond dip to white transitions etc and move towards using particle playground and lense flare transitions where would be a good resource to work through some tutorials? ( I am a Lynda.com member)
    Any advice welcome 🙂
    Tudor “ted” jelescu replied 11 years, 10 months ago 3 Members · 4 Replies
  • David Honan
    October 14, 2014 at 4:39 pm
    P.s.. Like these light transition fx here https://www.dailymotion.com/video/x15kdkg_15-massive-light-transitions-pack-after-effects-template_shortfilms but is it the case you normally have to buy these as additional plugins?
  • Todd Vanslyck
    October 14, 2014 at 8:17 pm
    I’ll echo Dave and say use transitions sparingly.
    Content is king!
    But they are nice sometimes. I use the filmimpact.net transitions. They are pretty useful.
    I’m not sure if BorisFX is still in the transition game, but they used to have a bunch like what you are describing.
    You could also try using some practical footage, like bokeh, or light leaks to make your transitions. Drop it on a layer above your two clips and do a quick fade up/down.
    Looks less “transition-ey” if that makes sense
    TVS
    Dell T76000 Dual 8-core 2.4 GHz
    NVIDIA Quadro 2000
    NVIDIA Tesla c2075
    Adobe Premiere Pro CC
    After Effects CC
    Cinema 4d r14
  • David Honan
    October 15, 2014 at 9:10 am
    Thanks Todd, your post has began my education. When your a rookie you see things you like but you dont know the names and if you dont know the names you cant research the “How to” tutorials
    Grazie mille 🙂
  • Tudor “ted” jelescu
    October 15, 2014 at 11:29 am
    To add to what has already been said, your transition need to add and not distract from your content, to help and not to break the flow of the story (unless your story needs to break). I would start with the basic presets from After Effects – there’s a bunch in there that are quick and easy to apply and use (as well as in Premiere). The trick is to take a preset and start tweaking it to make it look different. Adding other elements like blurs, glows, lens flares, grain and so on can improve the look of a transition. Of course all those things can be used in themselves to create transitions. Card Wipe and Card Dance can provide some interesting 3d transitions.
    But, as I said in the beginning, transitions need to be integrated in the overall concept of your piece.
    Tudor “Ted” Jelescu
    Senior VFX Artist
