Activity › Forums › Adobe After Effects › how to pull tricky key – thin dark lines on grey ?
  • how to pull tricky key – thin dark lines on grey ?
    Posted by Daniel Crooks on September 25, 2009 at 8:37 am
    hi people
    I have some footage of a kite where the grade i want to use pushes the light grey sky pretty much to pure white, yet I want to preserve (and ideally enhance) the thin black lines of the strings. I’m having real difficulty working out a way to do this. Due to the graduation in the sky I can only pull a good key on a very small section at a time. I’ve tried all number of keys, mattes and blending modes. If it was only a few frames I’d probably start painting but the shot is almost a minute long !
    Any suggestions greatly appreciated.
    I’ve attached a jpeg with the raw image, the intended grade + a hi-con to show the ‘strings’ and the graduated background that are there in the file.
    cheers../daniel
    Daniel Crooks replied 16 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
