Activity Forums VEGAS Pro How to pull off this effect???
  • How to pull off this effect???
    Posted by Aswin Dev p k on November 10, 2011 at 6:14 pm
    Hay . I am new to the forum. I have been trying vegas pro 11 since it’s release. I would like to know how to create the following effect.
    I have a white text on the screen with black background. I would like the text to get the color of a paint or ink when the paint is droped on to the text( The paint drop or paint flow is another clip ). For example if paint has color blue the text has to become color blue at those parts where the paint touches, at the exact time the paint touches it .
    Just like the Differnce Squared composite mode but with the same color as bottom clip not difference
    I know i could use the multiply composite mode to get the color of the upper paint drop track onto the underneath Text track . But the other parts outside the text will not be visible! I need all the text to be visible at all time. Can i use masks and multiple layers to achieve this?? Or is there another way??
    John Rofrano replied 14 years, 9 months ago 2 Members · 2 Replies
  • Aswin Dev p k
    November 12, 2011 at 3:57 am
    This is what the effect should look like
    Assume i have the paint spatter videoclip
    The color must stay after the paint spatter touch the text.
    https://www.youtube.com/watch?v=3dgAdi_4T1k
  • John Rofrano
    November 18, 2011 at 12:52 pm
    [Aswin Dev P K] “This is what the effect should look like”
    That’s an illusion. There are actually two versions of the text. One is gray and the other is pink. When the pink paint passes over the text, a wipe is used underneath to transition from the gray text to the pink text. You can easily do the same.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
