Activity › Forums › Apple Final Cut Pro › How to publish part of a timeline?
  • How to publish part of a timeline?
    Posted by Larry Watts on March 6, 2012 at 10:57 pm
    Is it safe to assume that if you have a selection set smaller than the total timeline and you publish it,
    that it will be limited to the selection area?
    I want to break up a 1 hour project for you tub into 3 separate uploads.
    Larry
    Matthew Celia replied 14 years, 6 months ago 3 Members · 3 Replies
  • Eric Santiago
    March 7, 2012 at 12:19 am
    At FPCX current state no.
    You can duplicate the project then put everything into a compound clip then duplicate that project three times each cut the way you want.
    thats the theory, Ive never had to do it.
  • Eric Santiago
    March 7, 2012 at 12:41 am
    Just did a test and it worked.
    Im sure I read that tip here at CreativeCow 🙂
    Thanks for that one whoever you are 😉
  • Matthew Celia
    March 7, 2012 at 2:20 am
    When you share using compressor you can select the specific region you want via IN and OUT points in the preview window. It’s an alternative to creating compound clips and multiple projects.
    FCP Guru
    http://www.fcpguru.com
