Activity › Forums › Adobe After Effects › How to properly use Fieldskit Deinterlacer in Premiere Pro 2017
  • How to properly use Fieldskit Deinterlacer in Premiere Pro 2017
    Posted by Alex Shapcott on August 12, 2018 at 10:06 pm
    First time poster here.
    I’ve been struggling to find the correct workflow for using Fieldskit Deinterlacer in Premiere Pro 2017. All tutorials and manuals focus on After Effects, but there is no clear direction for Premiere. Given all the different deinterlacing settings within Premiere, its confusing as to how I am suppose to set up a sequence in order to accurately use Fieldskit for the best result.
    My footage is 29.97 Interlaced, which I would like to convert to progressive.
    Any help is greatly appreciated! Thanks.
    Pierre Jasmin replied 8 years, 1 month ago 2 Members · 3 Replies
  • Pierre Jasmin
    August 13, 2018 at 2:21 am
    Do you have a field issue or a 3/2 pulldown issue (all frames have fields or just some)?
    Select the clip in Project Bin, right-click mouse menu Modify-> Interpret Footage
    Does it say Progressive or provides a Field Order?
    Is the sequence settings progressive or with fields?
    You can drop a clip to https://www.hightail.com/u/revisionfx
    Maybe easier like that
    Pierre
  • Alex Shapcott
    August 13, 2018 at 9:44 pm
    Hi Pierre,
    Thank you for your quick reply!
    Answer: all frames have fields. Motion appears to stutter (frames appear to duplicate). I’d like to eliminate or greatly reduce this. I’m hoping that properly deinterlacing with Fieldskit can greatly help, but I’m unsure if I am doing it correctly within Premiere Pro 2017.
    Answer: Fields are lower
    Answer: I’ve tried both. I don’t notice any difference when using Fieldskit in a sequence set to either/or
    Answer: I’ve submitted a clip for your review. Hopefully it will help diagnose the issue better.
    Thanks again!
  • Pierre Jasmin
    August 13, 2018 at 10:51 pm
    I got your movie
    1) Note in Display Monitor menu (right click mouse) – look for Fields – notice by default in interactive mode Premiere is set to show first field only – if you are at display and paused resolution 100% – you should see in a Field Project the image changing when swithching from one to other (first versus second field). You see field artifacts but you don’t see the action being a 1/2 frame timewise apart.
    2) Looks like your movie is just incorrectly labeled fields – set to Progressive in Interpret footage and set Sequence to Progressive – however it’s actually 15 FPS somehow – old camera used to do that with low-exposure situation… so you do have doubling of each frame.
    Pierre
