Activity › Forums › Apple Final Cut Pro Legacy › How to properly de-interlace still frame before exporting it
  • How to properly de-interlace still frame before exporting it
    Posted by Victoria Murphy on September 17, 2008 at 12:44 am
    I want to export a freeze frame of NTSC DV so I can use it to create a mask in Photoshop, which I will then import back into FCP. I made a freeze frame but when I viewed it in Photoshop I noticed some haziness around the edge of the part of the image around which I want to create a mask. I think is due to something funky going on with the fields. Should I de-interlace the freeze frame in FCP before I export it? What field should I start with? (I hope I am asking the right questions, it’s been a while since I have dealt with field-interlace related issues.) Thanks.
    Victoria
    Victoria Murphy replied 18 years ago 2 Members · 2 Replies
  • Don Greening
    September 17, 2008 at 5:59 am
    [Victoria Murphy] “Should I de-interlace the freeze frame in FCP before I export it?”
    You can do the de-interlacing in Photoshop. Look in the filters under “Video”. The field order for DV NTSC is lower field first so play with the de-interlace filter in Photoshop until it looks right.
    – Don
  • Victoria Murphy
    September 18, 2008 at 1:30 am
    Thanks, Don. I’ll get a chance to try this till tomorrow.
    Victoria
