Forums Avid Media Composer How to prevent multicam audio from switching?
  • How to prevent multicam audio from switching?
     Juan Juig updated 3 weeks ago 1 Member · 1 Post
  • Juan Juig
    July 6, 2021 at 9:40 am
    Hello,
    In the old version of Avid, when you pressed the up or down arrow key, only the video of a multicam (multi)group clip would change (for example from Cam A to Cam B) and it didn’t matter which tracks you had selected in your timeline.
    I noticed that in the newer versions of Avid this has changed. If your video track (for example V1) is not selected and you press the up/down arrow key, the first audio track that is selected (A1) changes (for example from external sound to Cam A sound).
    I don’t want that to happen, since I want to always leave audio as it is for all the (multi)group clips, because the audio from an external audio recording device is the only one that I will ever use.
    Is it possible to turn this off? To somehow make Avid switch only between the video clips of a (multi)group clip regardless of which tracks in timeline are selected?
    Best regards,
    Juan
Viewing 1 of 1 posts
Log in to reply.
