Activity Forums Maxon Cinema 4D How To Prevent Dynamic Objects From “Freaking Out”
  • How To Prevent Dynamic Objects From “Freaking Out”
    Posted by Ryan Paterson on May 7, 2014 at 9:41 pm
    What are some good methods to prevent the “exploding freakout” effect that happens when 2 objects begin the simulation touching each other ie) after having broken them apart with Thrausi
    Ryan Paterson replied 12 years, 3 months ago 4 Members · 4 Replies
  • Brian Jones
    May 8, 2014 at 12:39 am
    with Thrausi you shouldn’t get explosions if you haven’t done anything with Margins or Size Increment in the Dynamics Body tag Collision tab. It usually just starts to separate right away if the Trigger is still set to Immediately. The way to stop that is to turn off Self Collisions until you need it. But it depends on what behaviour you want – what is your Thrausied object supposed to do?
  • Cassius Marques
    May 8, 2014 at 8:07 pm
    You can simulate forward 1 frame and set that as your initial state. Its usually enough to avoid intersections.
  • Adam Trachtenberg
    May 8, 2014 at 9:10 pm
    If the object is really small it could potentially be an issue with the scale in project settings>dynamics.
  • Ryan Paterson
    May 10, 2014 at 4:04 pm
    Adam I think that might indeed be the problem, going to adjust my scene scale, thanks!
