Activity Forums Adobe Premiere Pro How to prevent bin windows from opening up in their own window
  • How to prevent bin windows from opening up in their own window
    Posted by Chris Craig on June 8, 2016 at 10:32 pm
    Hi
    Each time i open a bin window, it opens up into a floating panel. Ive looked in the preferences to change this to a more managable tabbed option, but can not find how to effect this. Can anybody suggest how i can do this?
    Thanks very much.
    Chris Craig replied 9 years, 10 months ago 3 Members · 5 Replies
  • Duke Sweden
    June 9, 2016 at 1:56 am
    Yes! Click on the three stripe thingy in the upper right corner of the main project panel, then Panel Group Settings> then check “Stacked Panel Group” and “Solo Panels in Stack”.
    Keeps everything nice and neat.
  • Sean Franklin
    June 10, 2016 at 12:52 am
    Inside of general settings you can set the default behavior of double click, ctrl click, and alt click. I believe you are just looking to change double-click to open new tab.
    -Tim
    Tim Franklin
    Watchout System Programmer/Compositor – CBS Sports
    Freelance Visual Effects Artist/ Video Editor
    http://www.TimSFranklin.com
  • Chris Craig
    June 10, 2016 at 8:57 am
    Thanks. I have tried this, however it will not work for me. It still opens in a floating window each time i open a bin in the project window
  • Duke Sweden
    June 10, 2016 at 12:14 pm
    I forgot that step. Do what Tim says, THEN follow my instructions to have the tabs open one above the other so you don’t have to scroll left to right to find a bin inside the project panel.
  • Chris Craig
    June 11, 2016 at 10:06 am
    That is exactly what i was after. I can’t believe i missed that setting.
    Thanks so much Time.
