Activity Forums Adobe After Effects How to prevent Audio Spectrum effect from clipping at layer’s edge
  • How to prevent Audio Spectrum effect from clipping at layer’s edge
    Posted by Dave Slydell on April 26, 2015 at 12:52 am
    I created an ellipse mask around the object in the below image, and I set the Audio Spectrum effect to that mask. When the effect animates, you can see clipping occur where the object’s layer ends. How can I make it so the effect goes past the edge or does not clip? Thanks in advance.
    Roei Tzoref replied 10 years, 1 month ago 3 Members · 3 Replies
  • John Cuevas
    April 27, 2015 at 2:54 pm
    Just make a much larger solid
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dave Slydell
    May 1, 2015 at 10:40 pm
    Thank you, it took me too long to figure that out…
  • Roei Tzoref
    August 21, 2016 at 11:31 pm
    you should set your mask to “None” and it will not be clipped. had to learn this obvious thing from a kid on Youtube 🙂
