Activity Forums Adobe After Effects how to preserve trasparency
  • how to preserve trasparency
    Posted by Kai Indvik on October 12, 2008 at 3:49 pm
    How can I preserve transparency in a video that I export from After Effects? I am creating a set of prekeyed stuff, and I need to know how to keep the transparency in the finished video file. I want this for when you drag the video into after effects, you don’t have to key it out yourself.
    Thanks in advance
    Kai Indvik replied 17 years, 11 months ago 3 Members · 4 Replies
  • Andres Fernandez
    October 12, 2008 at 6:42 pm
    Render the video with the mask at 50% opacity and with you be your alpha
  • Kai Indvik
    October 12, 2008 at 8:22 pm
    i’m not using a mask, though.
    I am using the color range key option.
  • Bruce Rudolph
    October 12, 2008 at 11:44 pm
    you need to export using a format that supports alpha channels.
    Try exporting with the animation codec, colors set to millions+
    (the + is the alpha channel)
    B
  • Kai Indvik
    October 13, 2008 at 1:22 am
    thanks!
    it worked great.
