Activity Forums Adobe After Effects how to precompose multiple 3D solids at one go?
  • how to precompose multiple 3D solids at one go?
    Posted by Manojit Ghose on April 25, 2012 at 8:34 am
    hello everyone,
    i have a comp with “n” number of 3D solids.
    what i want is to nest each of them into their own composition with [“leave all attibutes” to the current composition] option. so i can change the content inside each independently.
    any ways/script to do it at one go? (with having to manually nest each of them)
    thanks
    m.
    MG
    Manojit Ghose replied 14 years, 5 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    April 25, 2012 at 8:04 pm
    You may want to check aescripts for that, but just in case you did not think about this option here it is:
    Select 3d solid layer Alt click and drag over the footage or image you want to replace the 3d layer with- no need for a precomp. In case you really need a precomp, you can create a Master Precomp, the size of your 3d solid, duplicate that every time you want to replace a solid and apply the above mentioned Alt click and drag over.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Manojit Ghose
    April 25, 2012 at 8:48 pm
    hi ted,
    i tried aescripts but unfortunately no luck yet! or maybe i didnt look well enough.
    i am already using the method you mentioned. however since the source videos are of all different size, i have to manually scale most of them to match the original solid’s size (which is basically a grid of solids). but i guess i will have to live with that.
    but thanks for the reply 🙂
    MG
