Activity Forums VEGAS Pro How to Pre-Render in SVP 15
  • How to Pre-Render in SVP 15
    Posted by Christian Dongon on March 13, 2018 at 1:50 am
    I can’t figure out how to pre-render clips with twixtor effects in SVP 15. I’ve tried pressing “ctrl + shift + b+” and “shift + b” and it does nothing. But it does make the white marker move automatically through the clip. But I don’t see a change and can only see the actual result by rendering the whole video and saving it as mp4.
    Graham Bernard replied 8 years, 6 months ago 2 Members · 1 Reply
  • Graham Bernard
    March 13, 2018 at 3:26 am
    [Christian Dongon] “I can’t figure out how to pre-render clips with twixtor effects in SVP 15.”
    SHIFT + M makes Prerenders.
    [Christian Dongon] ” I’ve tried pressing “ctrl + shift + b+” and “shift + b” and it does nothing.”
    “ctrl + shift + b+” – Has nothing to do with Rendering. It makes available the Master Tracks View. Whilst “shift + b” will create a Preview built in RAM (it is volatile). You can ADJUST the amount of RAM available for this by going to Options > Preferences > Video and adjusting the amount of RAM you wish to make available. I just tested an 8 second TWIXTOR Event using a setting of 10,000Mb. Worked like a charm. I do have to remember that this has to be adjusted back, back in Prefs ????
    * Grazie
