Activity › Forums › Apple Final Cut Pro Legacy › How to play sequence backwards?
  • How to play sequence backwards?
    Posted by Anna Lord on April 10, 2009 at 6:27 pm
    I want to reverse the material on my whole sequence which consists in numerable clips, plus I want to invert the order of the clips as well. thus I want to see my whole sequence played backwards.
    Does anyone know how to go about this in another fashion than doing it clip by clip, which is miserably time consuming??
    Thank’s !
    anakronika
    Andy Mees replied 17 years, 5 months ago 5 Members · 6 Replies
  • Walter Biscardi
    April 10, 2009 at 9:49 pm
    Duplicate the Sequence.
    Nest the entire Sequence.
    Modify > Speed > 100% reverse.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • John Fishback
    April 10, 2009 at 9:59 pm
    I’ve never tried this on a sequence, but maybe nest the sequence and use Time Remap, Reverse, in the Motion tab and see if it works.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Anna Lord
    April 11, 2009 at 12:04 am
    thank’s. I nested it and then used the apple+j button and ticked reverse. I have a feelin it worked out but it’s rendering now so I’m not sure. If not I’ll let you know so you won’t have to make the same mistake.
    Thank’s a lot!
    anakronika
  • Anna Lord
    April 11, 2009 at 12:05 am
    Thank you!
    anakronika
  • Rafael Amador
    April 11, 2009 at 1:06 am
    Hi Anna,
    FC have a problem playing footage backward.
    If you are playing, lets say DV footage (Lower-first) in normal play te Lower fields are read before the Upper.
    Playing the footage backward, the Upper fields should be read before the Lower. But FC do this wrong. Keep reading Lower before the Upper.
    There is a free plugin from Nattress (Reverse: https://www.nattress.com/Free/freeFCP.htm)
    to help you to avoid this problem.
    Just drop it on the nested sequence.
    rafael
    http://www.nagavideo.com
  • Andy Mees
    April 11, 2009 at 6:23 am
    or add the built in shift fields filter to the nest
