Activity › Forums › Panasonic Cameras › how to play mxf file in fcp or avid
Posted by Gspchowdary on November 18, 2007 at 7:53 ami have a panasonic p2 502 cemara i copy to cemera hard disk to system hard disk, only mxf files its not playing and not importing. please help me.
Alex Petrovitch replied 16 years, 5 months ago 3 Members · 2 Replies -
Shane Ross
November 18, 2007 at 4:29 pmWell, what version of FCP are you using? Avid? With FCP 5.0.4 to FCP 5.1.4 you need to use the IMPORT PANASONIC P2 option:
With FCP 6.0 and up, you use FILE>Log and Transfer.
Avid Adrenaline has it’s own workflow…and I am not sure of that.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Alex Petrovitch
April 6, 2010 at 7:12 pmQuestion out there for everyone:
Is it better to get footage from P2 cards by importing/ingesting the CONTENTS and LASTCLIP via “P2CMS” or “SHOTPUT PRO” than going into FCP7 and just importing already made MOV files?
Is it better to have the audio and the MXF files separated as in the P2CMS transfer? what the hell is an MXF file? Is there data loss when doing the MOV transfer?
Also – when dragging the MXF file onto a timeline, FCP7 gives you “suggested” settings for the timeline. I shoot in 24fps, but it suggests DVCPRO HD 1080i60. Why the “60”.
Also – my footage seems to be having lines on the subject when they move quickly – is that because I shot in 1080i, instead of using 720p. (I am using the HVX200)
thanks!
