Activity Forums Adobe After Effects How to perfectly centre anchor point?
  • How to perfectly centre anchor point?
    Posted by Olly Lawer on August 17, 2012 at 4:42 pm
    I have some cogs. I am trying to get the anchor point centred in the middle of the cog but there is nothing to go on – no marker. How do I get the anchor point to perfectly centre do you think so the cog turns seamlessly.
    Olly Lawer
    Olly Lawer replied 14 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Roland R. kahlenberg
    August 17, 2012 at 4:55 pm
    Which application did you use to create the cogs or are they stock imagery?
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Olly Lawer
    August 17, 2012 at 4:59 pm
    My illustrator did them in ai. I don’t have access to ai.
    Olly Lawer
  • Alejandro Pérez blanco
    August 17, 2012 at 5:02 pm
    You may get what you want by typing the layer’s width and height values and then dividing by 2.
    You have to choose layer size when you import them, though.
    August 17, 2012 at 5:06 pm
    I assume that individually each cog was not centered in the canvas when he created them and that you have a multi-layered AI file and that you imported the file as a composition WITHOUT selecting the Retain Layer Sizes option.
    If yes to all of the above then select the Retain Layer Sizes option when you import the AI file as a composition. If I’m way off then please do us a favor and provide more info, including a snapshot of your timeline and the comp panel.
    Cheers
    RoRK
  • Tudor “ted” jelescu
    August 17, 2012 at 5:08 pm
    If you import the AI file (assuming the cogs are on separate layers) as a composition – layer size- if you create a new comp and then drag each layer individually in the timeline you should get each layer perfectly centered with the anchor point right in the middle.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • John Cuevas
    August 17, 2012 at 6:06 pm
    I’m not sure this will be of benefit to you(some of the other suggestions may work better for this situation) but there is a “name-your-price” script at AEScripts that will reposition the anchor point of layers.
    RepositionAnchorPoint Compatibility After Effects
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Olly Lawer
    August 17, 2012 at 6:14 pm
    Thanks. Got illustrator to add in cross hairs in AI, but still not perfect. It’ll do!
    Olly Lawer
