Activity Forums Adobe Illustrator how to pathfinder crop properly?
  • how to pathfinder crop properly?
    Posted by Piotr Raczko on May 16, 2013 at 11:10 am
    Hello, I have a problem with pathfinder cropping. I have a bunch of diagonal blue lines and I drew a transparent square on top of that. When I hit crop, I loose all the lines, and only the transparent square remains. I also tried a white filled square, but then a white square remains. However I want to crop the lines to a square shape, so that I can make a seamless pattern. What am I doing wrong?
    Thanks a lot for all help!
    Per Arne sandvik replied 13 years, 3 months ago 2 Members · 1 Reply
  • Per Arne sandvik
    May 22, 2013 at 5:51 pm
    Vector lines won’t crop like that, you’ll have to make them filled objects.
    Highlight all the lines (but not the transparent square on top) and choose object > expand. The lines are now filled objects and can be cropped in pathfinder. Using the method you described.
