Activity › Forums › Adobe After Effects › How to paste layer to multiple composition at once?
Posted by Ujin Roh on January 9, 2019 at 3:22 amI copy a layer from one composition and paste it into another composition. But there are more than 100 compositions. Is there a way to paste the selected compositions in the Project panel at once?
Nikhil Kannur replied 6 years, 3 months ago 5 Members · 4 Replies -
Oleg Pirogov
January 9, 2019 at 9:36 pmIn case you’d like to use a script, it’s 2 lines of code literally:
for (i = 1; i<=app.project.numItems; i++){
if ((app.project.item(i).typeName=="Composition") && (i!=1)) app.project.item(1).layer(1).copyToComp(app.project.item(i));
}This copies the layer (app.project.item(1).layer(1)) to all comps. That’s assuming that deleting it from the wrong comps is easier than copying it to the target ones.
Erik Borzi
September 7, 2019 at 8:09 pmOleg!
Thank You Very Much for this powerful script!!! It works great!
—Erik
Alex Bradley
March 30, 2020 at 4:30 pmHi!
I’m hoping to paste a layer into multiple comps too. It sounds like this solution works, though could someone explain in a little more detail how to make the script run?
Nikhil Kannur
June 3, 2020 at 12:01 pmcould you please help in using this script, because I am a novice in scripting I can’t understand
the working of this script. -
Orlando Marconi
October 3, 2020 at 3:01 pmCould you give a hint on how to apply this?
What to modify for each case?
I tried and failed.
Thank you
