Activity › Forums › Adobe After Effects › how to pass project from mac to pc and back?
  • how to pass project from mac to pc and back?
    Posted by Greg on April 19, 2005 at 2:34 am
    i had a project that i passed of to someone to work on via lacie drive, he is on a pc im on a mac , he had no problems reconnecting all the files used in the project. he has now passed the project back to me via the same drive, an i can connect everything except psd. documents that were imported as comps because i can not figure out how to access the psd.layers on the hard drive i can find the psd. itself but how can i access the layers???? these are files that i created before giving him the project any help would be greatly appreciated as i am going crazy
    thanks
    greg
    btw we are simply using “collect files” saving to hard drive and passing the drive off
    ps. shortly after giving him the lacie my computer crashed and i lost the orignal psd. docs
    Greg replied 21 years, 5 months ago 2 Members · 2 Replies
  • Filip Vandueren
    April 19, 2005 at 2:37 pm
    Hi there,
    the missing PSD layer-files should show up with Italic text names in your Project-Window.
    Just double-click on one, and you get a fileselector prompting you to locate the file.
    Now first locate the PSD file, and in the next dialog you get choose the correct Layer from the pop-up. AE should figure out what other layers it’s missing are in that file too, and reconnects them, so you only have to do this once for every psd-file, not for every layer.
  • Greg
    April 19, 2005 at 3:14 pm
    thanks i got them to reconnect but it took about 2 hours because i had to manually reconnect every layer it didint automatically reconnect a single clip for some reason
