Activity Forums Apple Final Cut Pro Legacy How to Pan still photo without using after effects in FCP 4.5
  • How to Pan still photo without using after effects in FCP 4.5
    Posted by Dye Gray on November 29, 2005 at 5:07 pm
    I am cutting a documentary and want to incorporate still photos with movement. Is there a way to pan a photo or zoom in/out using FCP 4.5?
    Dye Gray replied 20 years, 9 months ago 4 Members · 4 Replies
  • Shane Ross
    November 29, 2005 at 6:14 pm
    Yes. Drop the picture into the timeline, then load it into the view and click on the MOTION tab. You can adjust the SCALE and the CENTER in here, and using Keyframes, move the picture. Time to open the manual and read up on keyframing.
  • Chris Poisson
    November 29, 2005 at 6:36 pm
    Dye,
    If you have to do a lot of these, check out PanZoomPro at lyric.com. Many times faster than the motion tab, plus no keyframes for transitions to push around.
    Have a wonderful day.
  • Dean Sensui
    November 29, 2005 at 10:57 pm
    While you can do pans and zooms within FCP some of them will end up looking better if done in After Effects. Should you run across tilts or zooms that just won’t render nicely then you can do those seperately in AE.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Dye Gray
    December 2, 2005 at 5:01 am
    Thanks for all of the advice. I downloaded the demo for PanZoomPro. I will take a look at it and see how I like it.
