Activity Forums VEGAS Pro How to pan across a masked layer while it stays put?
  • How to pan across a masked layer while it stays put?
    Posted by Tyler Kemp on June 17, 2014 at 9:11 pm
    I am attempting to green screen for the first time, and have an announcer standing next to a “screen” on the screen. How I can I pan a picture inside this screen?
    Currently a photo is in that layer with a mask around what I want showing, but I can’t figure out how to move the picture around inside the mask.
    James Halliday replied 12 years, 2 months ago 3 Members · 4 Replies
  • Tom Vance
    June 17, 2014 at 11:18 pm
    If I am understanding you, the “green” screen is a green screen that you want to put a picture into (like a newsreader with a picture behind them on a screen.) If that is the case simply put the picture on another track and resize/move the picture using track motion under the track that you have applied your chromakey.
    –tom
  • Tyler Kemp
    June 18, 2014 at 10:19 pm
    Close, there will be a screen behind me similar to a weatherman setup, however I also want to bring another smaller screen to my right with additional images and footage.
    I cannot figure out how to essentially make the smaller screen static, while moving an image around inside it.
  • Tom Vance
    June 19, 2014 at 3:27 pm
    Assuming it is just you before a greenscreen, I would simply put your other images/video on a track above you and your greenscreen and resize the track and move it to where you want it. Then, everything you do your pans and crops.
    tom
  • James Halliday
    June 19, 2014 at 5:23 pm
    Uh, I don’t know exactly what you’re asking, but I’ll try to help.
    If you have a person in front of a green screen and you chroma key’d it already then just place the thing you want behind the person and pan it.
    Could you add a picture?
