Activity Forums Adobe After Effects How to paint on a mask layer with composition view
  • How to paint on a mask layer with composition view
    Posted by Gern Blanstein on March 1, 2008 at 8:10 pm
    In one project I have a layer (a picture) with a mask object; the mask is used to control the visibility of picture elements.
    I need to make very precise painting operations on this layer, and the only way that I can paint correctly is to ‘see’ the mask in real time (i.e., as a full composition).
    However, I am finding this procedure to be frustrating and futile in AE, because I can only paint on the mask while viewing the mask layer. AE’s render switch is useless here, and all paint tools are disabled when viewing the composition.
    Am I missing something, or does AE not support this type of operation?
    Any tips or work-around solutions are appreciated.
    Harriet Farren replied 14 years, 7 months ago 3 Members · 3 Replies
  • Gern Blanstein
    March 5, 2008 at 1:21 am
    I’ll assume the community is generally clueless on this matter.
  • Cosmin Gurau
    March 6, 2011 at 2:01 pm
    You know, I have the same exact problem. I can’t find anything anywhere. Have you found anything? The really cool part is that all the others don’t seem to give a rat’s ass. Come on, this is one of the first things I’ve tried to use after effects for. You’re telling me EVERYBODY else never tried/needed this? They solve all their problems with the pen mask?! It’s rather weird, man.
  • Harriet Farren
    February 13, 2012 at 1:01 pm
    you’ve probably already moved on from this, but for people viewing in the future via google search. BUT although i don’t know how to do this in aftereffects, what i would to, is the following:
    if your planning on ‘tracing’ a still image
    (so if you were tracing a picture of a cat face but it’s morphing, and you’re using the still image as a reference point), pop the still image into photoshop. go to window>animation (you then get a long bar at the bottom of your work panel, these are frames, which you can then draw onto layers, and set visibility to each frame you create (for more details, search ‘rotoscoping using photoshop’). then export as a video and import into your after effects project.
    ‘Tracing’ a video
    this is only do able if you’ve got 64-bit adobe photoshop cs5. do as above, but to import the video, go to file>import>video frames to layers. you can then adjust the fps rate to desired (i’d reccomend 12fps for high quality, 6fps for low quality) but only import 15 seconds of footage at a time other wise photoshop has trouble handling the file. (15s of video footage at 12fps is aprox equal to 150-180 images).
    again, this is only my solution from a ‘non aftereffects point of view’. i’m sure there is a way to ‘trace’ in after effects somewhere!
