Activity Forums VEGAS Pro How to overlay text? probably a 10 second solution
  • How to overlay text? probably a 10 second solution
    Posted by Stephen Pierce on November 7, 2009 at 11:13 pm
    Own Sony Vegas Pro 9, yet quite the amateur with video production.
    Certainly this is a 10 second thing for someone who knows how, but have spent four hours trying to figure it out – will appreciate your help.
    I have a video with a lot of rendered text. There’s a BIG TYPO that I need to cover up and insert the correction.
    In other tools, it would be simple to identify the region to black out or cover with new text, or by a couple of layers of operations.
    In Vegas, I can wipe out an entire screen, but don’t see any way to cover up the typo, much less cover and add replacement text.
    Thank you for your help!
    Stephen
    Stephen Pierce replied 16 years, 10 months ago 2 Members · 2 Replies
  • John Gleason
    November 8, 2009 at 7:06 am
    Find the media event which has the text you need “blacked out.”
    Click the Event Pan/Crop button on the media even in the time line.
    Check the “Mask” box in the lower left hand corner of the Event Pan/Crop window.
    Click the pen icon which says “Anchor Creation Tool” (or press D).
    Use the pen to create a “box” around the text you do not want.
    Click the Mode from Positive to Negative. [This should be right under “Path”]
    Create a new video track on top of your current track. Add a Media Event and put your new and improved text over the masked event below it.
    Profit?
    This works well when you have a solid background color. If you need to match a solid color, create a video track underneath your masked media event track and add a solid color to the timeline via Text Media.
  • Stephen Pierce
    November 8, 2009 at 11:49 am
    THANK YOU!
    This worked perfectly!
