Activity Forums VEGAS Pro How to only build peaks for audio tracks which don’t have them?
  • How to only build peaks for audio tracks which don’t have them?
    Posted by Frankie Jones on July 25, 2014 at 12:42 pm
    Is it possible to only build audio peaks for tracks which don’t have them. Vegas does this on import, but sometimes this has to be cancelled and peaks built later. Had been using Shift+F5 to rebuild, but rebuilds everything, including peaks on tracks which already have them in the timeline. Is there some way to either select which tracks peaks are built for or just build for those lacking them?
    Best,
    Frankie
    Frankie Jones replied 12 years, 1 month ago 2 Members · 2 Replies
  • Norman Black
    July 26, 2014 at 2:31 am
    Peaks are not per track but are per media file. If you delete the SFK file then the next time you open your project, Vegas will build the peaks (SFK) file again. That is the only way i know of to selectively rebuild a peak file.
  • Frankie Jones
    July 26, 2014 at 2:34 am
    Hey, found the answer for anyone else.
    It is possible, if you turn on build peaks in view in Internal Preferences then zoom in on the timeline to the ones you want rebuildling
