Activity Forums Adobe After Effects How to: Multi-Image Pan
  • How to: Multi-Image Pan
    Posted by Nathan German on January 11, 2018 at 8:35 pm
    I’m curious if anyone has any input on how to create a multi-image pan effect in After Effects similar to what is seen at the 1:23 mark in this video:
    https://www.youtube.com/watch?v=iokqGOQmt1U
    So far, the best method I have come up with is to simply arrange the images manually in 3D space, create a camera, and then animate the position of the camera to pan across the images, but I feel like that would take forever just laying out all the images. Anyone have any other method suggestions that may work quicker or more effectively?
    Walter Soyka replied 8 years, 8 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 11, 2018 at 11:24 pm
    You could use a particle system. Precomp and sequence all the images as a single frame each inside of a comp, then use that with “Random Still” mode as the texture for your particle.
    Or you could build the random assortment of photos with a script like this:
    https://aescripts.com/distributelayers/
    Or you could use an expression to randomly distribute the photos in space, then animate a camera or link them all to a null and pan it:
    // adjust these values to taste
    minX = -2000;
    maxX = 2000;
    minY = -1000;
    maxY = 1000;
    minZ = 0
    maxZ = 2000;
    seedRandom(index, true);
    value + [random(minX, maxX), random(minY, maxY), random(minZ, maxZ)];
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
