Activity Forums Maxon Cinema 4D How To Move Whole Animation All At Once?
  • How To Move Whole Animation All At Once?
    Posted by James Kozick on March 23, 2018 at 9:23 pm
    I’m creating human figure animations in Adobe Fuse/Mixamo and importing them into C4D. What I want to do is create in a single C4D file a couple of independent animated figures to be situated on different locations in global space. Each animation is independent and based on a different human figure; they are not interacting with each other nor are they connected to each other.
    When I import the animations into C4D, they both import at the same location with one importing on top of the other.
    How can I move each whole animation all at once to a particular location in global space? Should I be working with Motion Clips or not? If so, how?
    Please advise. Thanks!
    Mikel Ravizza replied 6 years, 1 month ago 4 Members · 10 Replies
  • 10 Replies
  • Brian Jones
    March 24, 2018 at 3:56 am
    you don’t need motion clips just the Animation Tool which lets you move the (I assume in this case) the rig around and it brings the animation with it.
  • James Kozick
    March 24, 2018 at 4:00 pm
    I’m not familiar with what Animation Tool you’re referring to – where it’s located and how to use it. I’ve looked and searched in C4D with no luck. Please advise how to locate it and use it. Thanks for your reply!
  • Brian Jones
    March 24, 2018 at 7:25 pm
    it depends a bit on the version of C4D you are using (and if you have customized the interface) but it should be on the upper-left of the editor window icons – the Model/Object/Animation Tools are there. It can also be reached via menus, in R19 it’s in Tools/Modes/Animation.
    The Help says:
    Animation
    When in this mode an active object’s entire animation path can be moved, scaled or rotated. Clicking on and moving keys individually is always possible.
  • James Kozick
    March 25, 2018 at 6:45 pm
    Thanks so much for your help.
    Now it works with the help of the Animation Tool. In R17 its buried a lit bit. But, once I located it, it works.
    Your help is most appreciated!
  • James Kozick
    May 27, 2018 at 2:59 am
    A while back I wrote with a request regarding how to move a whole animation all at once. These are MIXAMO animations I have downloaded and imported to C4D.
    The suggestion I received then was to use the Animation Tool – which worked just fine when used with the Move Tool. Now, I am attempting to rotate an animation all at once. I’m still using the Animation Tool which is still working fine with the Move Tool. However, when I attempt to use the Rotate Tool on the animation with the Animation Tool, the animation will not rotate. I thought it was originally suggested that the Animation Tool worked with rotate as well. But, it is not working with the Rotate Tool.
    Any suggestions how to get the Rotate Tool to work with the Animation Tool?
  • Brian Jones
    May 27, 2018 at 4:43 am
    Not that I know of (but not an expert), the rotate tool will work with the animation mode but it rotates the animation path not the object, as far as I know. I only played with one Mixamo (pre-Adobe). I understand from a post by Steve that there are a couple different formats but if it’s like the one I have you can maybe do what you want by grouping the rig parts hierarchy and the mesh hierarchy under a single null and rotate that null (with the Model tool).
  • James Kozick
    May 27, 2018 at 2:18 pm
    Thanks for your reply.
    I tried grouping all the parts under a null. What I found when I did that is not only did the animation not rotate when I attempted to rotate the null, but the Move Tool didn’t work either when attempting to use the Move tool to move the animation by moving the null. But, when I highlighted the rig alone, the Move Tool worked once again.
    If you have any other suggestions, please let me know.
  • Brian Jones
    May 27, 2018 at 6:01 pm
    it must depend on the structure we’d have to see the file
  • Leonardo Papini
    June 2, 2018 at 1:21 pm
    Hi James,
    i just saw this tutorial and maybe it could help you with your problem.
    https://www.youtube.com/watch?v=kzo2sp25gsA&t=429s
  • Mikel Ravizza
    July 20, 2020 at 2:05 pm
    Did you guys ever work this out? I realize its a bit old of a message.. Well I just had the same problem and read the comments.. They were very helpful, but I think issue here is the use of termonology.
    There is no “animation tool” per se. IT is a mode, we switch to the “animation mode” where then we can use the other tools. But what object do we pick?
    The designers at cinema4d are omni-present.. They antipicated that perhaps we would need to move entire animations in one go. Now there is a “model mode”../ There is a “object mode”.. There is a “polygon mode”. There are lots of modes! Each mode let’s us use different tools depending on the mode. And sometimes just to make things a little bit more confiusing (not to bag on the omnipresent cd4 programmers).. but using hair.. There is no “hair mode” but you have to use the “hair tools” to move scale and rotate in model mode (which look exactly like the other move scale rotate tools mentioned abobe.. Now I don’t want to lecture.. but in the compute world termonology is very important.. same for doctors..but I digress..
    OK.. the idea here.. we want to move an entire animation. I was struggling as I often do with the move tool, selecting all the keys.. in model mode. in object mode.. (I had seen animation mode but did not know what it was for). Now we know.. This mode assumes you pick only the top of the heirarchary, in my case hips from mixamo.. then switch to animation mode.. It looks like a film strip. The order doesn’t matter.. you can switch to animation mode, then make your selection or visa versa. The important this is the selection. IF you try to move.. the entire animation (ie in the view port the axis since I picked the entire heirarchy) has an average position. I tried but could not. I thought, could it be the people at C4D are so cool as to know what I want.. Justt to drag the hip bone (at the top of the heirarchy) to where I want it.. And everything else follows! Yes! they are that cool.. Hats off.. sorry for the long answer.. But maybe others will get to the point quicker.. Thank you for comments here they were helpful. thank u to the omnipresent at C4D. I love this fustrating program!
