Activity Forums Adobe After Effects how to move the AVI file in the timeline?
  • Todd Kopriva
    August 1, 2009 at 5:29 am
    Are you trying to move the whole layer in time, or are you trying to extend the layer in time?
    Instructions for doing either are here:
    “Move or place a layer in time”
    “Trim, extend, or slip-edit a layer”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Kevin Norman
    August 4, 2009 at 11:44 am
    I believe it has something to do with “where your scrubber tool is”
    Have you tried moving it down the timeline or to the end of you composition?
    If not give that a shot and then try to move your avi file(I ran into a similar problem last night and this worked for me, Good luck)
