Activity › Forums › Adobe After Effects › How to move mask paths over several keyframes all at once?
J.d. Frey replied 4 years, 5 months ago 15 Members · 39 Replies
Gustavo Saliola
July 25, 2017 at 5:14 pmI’m sure it’s a good solution, but it’s time for Adobe to address this and be in the real game like Mocha.
Every post in their request forums is a chance to be heard. Please write them!
Thanks.
Darren O’donoghue
August 31, 2017 at 11:23 amHi everyone, only just found this post after having the same issue, however managed to find a very useful tool made by David Torno via Lesterbanks website, which may save hours of painstaking searching and/or animating.
https://www.provideocoalition.com/mask-adjuster-free-after-effects-script/
Its an ingenious solution to a problem that shouldn’t exist in the first place.
Hope it helps.
D -
Roei Tzoref
September 1, 2017 at 2:13 pmThank you Darren. it’s pretty good and a workaround for some cases. of course it’s not a real uber key that will enable you to offset parameters other than position… for example scale/rotation but the real mind blower is the vertices themselves like Mocha’s Uberkey can do. if I discover for example after my roto is done that there is one offending vertex at a corner, if I press the uberkey I could shift it in place and the change will apply to all the keyframes.
Roei Tzoref
2D/VFX Generalist & Instructor Ae Blues Tutorials
http://www.tzoref.com -
Sam Rae
February 19, 2019 at 8:04 pm2019….Still a problem haha.
On my animation, I have multiple animated masks on the same layer (I wanted it this way).)…I want to adjust one of the masks in particular. But of course…Ditto…
Roei Tzoref
February 19, 2019 at 8:22 pmthere’s also this:
https://aescripts.com/keytweak/Roei Tzoref
♫ AeBlues Tutorials ♫
Sam Rae
February 19, 2019 at 8:54 pmWhoa KeyTweak looks awesome— that should do just what I wanted I also needed to adjust just a few vertices on some masks, yet the change was needed in the middle of the animation with lots of vertices. Thanks for the reply!
Gustavo Saliola
June 11, 2020 at 3:12 amHey Roei! It’s nice to “meet again” here, for the same mask issue with Adobe After Effects, a few years later! I’m working in a project which needed this! So, thanks The Cow!
Hope (all of) you’re safe in this times.
J.d. Frey
March 26, 2022 at 6:21 pmI can’t believe you still can’t do this in AE. I’m 99% sure I used to be able to modify all the keyframes for a shape path/mask path. I’m pretty sure you used to be able to alt-select or property select all the keyframes, cmd/ctrl +T to transform the path and it would update the shape relative to the current keyframe centered on the anchor point. This is ridiculous.
