Activity Forums Adobe After Effects how to move light along with camera when camera is controlled by null object.
  • how to move light along with camera when camera is controlled by null object.
    Posted by Kozo Okumura on April 1, 2012 at 3:04 am
    i have several layers in 3d space and having the camera traveling to visit those layers.
    I like to have the light move along with camera as in the real life situation like sun gun light attached to camera.
    if i move the camera directly, i can simply parenting the light position to the camera position and easily achieve what i want.
    but if i like to control the camera with null object, parenting light position to the camera position doesn’t give me the result i want. can you help me how to do this when camera is controlled via null object.
    Tudor “ted” jelescu replied 14 years, 5 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    April 1, 2012 at 7:11 am
    What do you mean by:
    “parenting light position to the camera position doesn’t give me the result i want”
    If you parent the light to your camera layer and the camera to a Null, the Light should move together with the camera, so I’m not quite sure I understand your issue.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kozo Okumura
    April 1, 2012 at 2:47 pm
    sorry, i should have wrote
    “parenting camera layer to null object ”
    you can actually try it. you see the light is not moving with camera anymore, this way.
  • Kozo Okumura
    April 1, 2012 at 2:51 pm
    sorry, i just figured this out.
    when i parent the light layer to the camera layer as opposed to position parameter, it does what i want.
    thank you!
    April 2, 2012 at 9:10 am
    That makes sense- when you parented the light to the camera position it did not move because the values of the position stay at 0 since you move the Null and not the camera itself. That is why you need to parent the light to the camera layer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
