Activity Forums Maxon Cinema 4D how to motion track?
  • how to motion track?
    Posted by Durwood Hibbard on March 2, 2014 at 7:46 pm
    I have an after effects template that I could just put a 2d logo into and it would look ok. But I would like to make the logo 3d in Cinema 4D (which I have already done) and use the 3d logo instead of a 2d image.
    My question: If I render out the AE comp that I plan on using the logo with to use as a reference, is there a way to import that footage into C4D and have it play so that I can get the 3D movement matched up so that when I render out the logo from C4D it will match up? If so could you please explain how to make this happen. Or if you have a better way of doing this I am open for ideas
    Thank You in advance
    Durwood Hibbard replied 12 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 2, 2014 at 11:44 pm
    Are you using a camera in AE or is it a straight 2D comp? If it’s a camera you can use Maxon’s AE to C4D plugin to bring it into Cinema … or vv.
    If you just want to use the comp render as a guide you can load it into a texture in Cinema and place the texture on a background object.
  • Durwood Hibbard
    March 3, 2014 at 2:36 am
    It is just a 2d comp with a null for the motion. I have been able to bring a picture as a texture in to C4D but it only helps to an extent. I might look at some other options for this time around.
    Yes, Yes I do realize I have no clue what I am saying.
