Activity › Forums › Apple Motion › How to modified second keyframe using slider
Posted by Doni Donovan on January 20, 2017 at 12:58 pmHi,
Can some tell me is possible to change the last value that already have 2 keyframes using a slider?
i really hope someone can help meRobin S. kurz replied 9 years, 8 months ago 2 Members · 6 Replies -
Robin S. kurz
January 21, 2017 at 11:33 amOdd question. Without knowing which parameter we’re talking about and/or far more precisely what it is you’re trying to do, this could only turn into an endless guessing game.
If it doesn’t have a slider, there’s no sliding. But pretty much every parameter value can be scrubbed.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Doni Donovan
January 21, 2017 at 5:57 pmHi Robin..
For example i have 2 keyframes which is moving the x position of rectangle from 0 to 100..
Ao i want to change the second keyframe (100) by slider without changing the first keyframes (0) -
Robin S. kurz
January 21, 2017 at 6:50 pmThat’s what I suspected.
You can publish the position parameters as a whole, but you cannot publish any one value of any one keyframe, no.
– RK
Doni Donovan
January 22, 2017 at 1:09 amThanks for your answer Robin.
I know we cant publish only one of two animated keyframes but i am sure apple motion can do that in another way..
Maybe using rig or behavior but i dont know i am still new with motion -
Robin S. kurz
January 22, 2017 at 4:34 pmAgain, without knowing exactly what you’re trying to do, there is little in terms of specifics I can give you.
Maybe take a look here: https://www.rippletraining.com/products/motion/rigging-publishing-for-motion-5/
– RK
